Relays, coil ??
Discussion in '1983-2005 S-Series models' started by 90blzr, Dec 6, 2003.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Okay went to fire the biatch up (S-10) after swampping everything. No power to the coil/forums/images/graemlins/angryfire.gif Any thoughts? Oh by the way...its an '84 S-10 truck with a V6.
    What the hell would cause that? It cranks and cranks, gets fuel, all the lights everything works fine, put wont start up!
    If it was the iginition module, the coil would still get spark right??
    It ran CHERRY before the swap a couple days ago.
    Also wondering there is what looks like some kind of relay on the firewall right above the master cylinder with a few wires that plug into it...one of them being about a 12 guage pink wire....the same color size going into the coil....could that relay have gone bad? or is that relay and the coil even related at all?
    Thanks!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i say swap out that relay with another, its probably the coil relay..
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Was gonna try that, but happened to look under the dash and one of the wires came out from the column when we replaced it with the new one. And what do ya know...I plugged that pink wire in (same as coming out of the coil) and it starts!!/forums/images/graemlins/thumb.gif/forums/images/graemlins/thumb.gif
