Relays for brighter headlamps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ryan22re, Jul 25, 2005.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    last year i added two relays to my 87 and man what a difference. i used two relay kits from gm (actually its a starter relay recall part) part # 22694036, which is a relay with a short wiring harness use part # 88880045 for a longer harness. i used the original power wires to the low beams to energize the relays, and used some heavier wire run from juction block on the firewall to power the head lamps. i also ran heavy gauge wire from the low to high beam. i went from around 11.8-11.9 volts at the lamps to about 14.0 volts. the difference was amazing. dont have the part numbers of the terminals i used to attach the heavy gauge wire to the headlamp connectors, but i could get it if any one is interested. could also draw a wiring diagram. total cost was around $40.
    ryan
  2. J.R.
    J.R. Guest
    i would be interested in a write up and diagram on what you all did!! thanks
  3. pos727
    pos727 Newbie
    Nov 20, 2004
    3
    South Florida
    I second that. Thanks
  4. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    i would do this as well.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    ok guys am working on diagrams part #s and some digital pics.
    i'll probably do diagrams for both single and dual headlamps.
    ryan
  6. dyeager535
    26,978
    Is this what you are talking about doing?
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yes thats what i am talking about.
    ryan
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    but the way that i did it only requires two relays and will keep the low beams on while the high beams are on. the way i read that diagram, it is really written for just single lamps.
    ryan
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    why is stock voltage lower than 14 in the first place ? GM have a reason or is is due to resistance of the stock wiring ??
    hmm..
  10. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    it is due to the small gauge wire and the length of the wires.
    ryan
  11. dyeager535
    26,978
    Yep. You'll typically see at least a .5-1V drop at the fuse panel alone from alternator output voltage. When factoring in all the other connections/wire between the firewall and the headlights (light switch, etc) I can imagine quite a bit less.
    Easy enough to test, check voltage at the alternator with the headlights on, then pull a headlight plug and test voltage there.
