Relays
Discussion in 'The Garage' started by blazerpro79, Jun 1, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    how do you wire a relay? when i bought my lights and fan they never came with any info on relay wiring or even a relay. many people advised me to wire them through a relay, so i bought a few, can someone tell me where each of the 3 wires go? thanks in advance
  2. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    This is the diagram I used for my rock lights, elec lockers, etc.
  3. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    nice diagram! but i have a question
    why does 30 go to the battery, and 85 goes to a power source too?
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    30 is your high amp contoleed power
    85 is your low amp control power
    When power is applied to 85, then the coil is energised, then the contacts close providing a path for the power across 30 to 87.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Think of it this way.
    Power to the 85 terminal "turns on" the relay allowing high currant flow from term 30 to the 87 term.which in turn powers whatever the relay is connected to.
  6. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Wiring for that relay setup - I think I used 12 gauge for the batt-relay-lights run, 14 or 16 gauge for the switch run.
  8. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    ok makes sense thanks a lot! hopefully today will clear up and i can go drop them in.
    another quick question, some relays have an 87 and 87a. does that mean you can connect 2 separate objects together? i.e. 2 separate sets of lights?
  9. rpellicer
    rpellicer Registered Member
    Dec 20, 2004
    38
    Susanville, CA
    87 is hot when 85 is has power, 87a is hot when 85 doesn't have power. There are some relays (DPST I think) that have two 87 terminals rather than an 87 and 87a. These can run two outputs at a time.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
