relocating ft. and rear axle's
Discussion in 'The Garage' started by nova, Jun 14, 2004.
  1. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    relocating ft. and rear axle\'s
    i have a 77 blazer with a 6 inch lift ,dana 60 detroit electrac, 14 blt detroit locker, 42 inch tsl's, doubler kit and cross over steering. i want to move the front axle 2 inches and the rear axle 4 inches to equal out the drive shaft's some.
    i have heard of people using 52 inch rear springs in the front and 56 inch rear springs in the rear to do this exact same thing. does it work ? how do you do it exactlly ? any other ideas would be great to. i don't want to add hight to my ride just length. /forums/images/graemlins/ears.gif
    please help me out /forums/images/graemlins/bow.gif
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: relocating ft. and rear axle\'s
    wait, do you want to move the rear 4" back and the front 2" forward? moving 4" back will require moving frame mounts or some other spring setup. 56s have the same center pin location so that won't move the axle. Zero Rates will only more your axle 1.5". If that was enough I'd just remove the front axle and drill holes in the spring perches so that the center pin falls in different holes and it will move your axle forward 1.5".
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    turning the 56" around moves the axle back 4".
    and putting the 52's up front will push ya forward 2"
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    If you turn the 56's around, will that effect flex or anything, or it the same, just different mounting spots?
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    they will flex the same, but I'm pretty positive ann angled shim will be needed.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, are shackle flips still possible with turning the springs around? I like the 4" back idea /forums/images/graemlins/thinking.gif
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    very much so.
  9. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    i found a set of 56 inch springs and the center pin is located at 26/30 inch. this will infact make the 4 inch difference i was looking for. i was thinking of getting a ORD 4" shackle flip and 2" lift springs to help the pinion angle out. and yes to the question i will have to move the rear shackle farther back, 4" infact. /forums/images/graemlins/thumb.gif
    so that leaves the front end with a problem. what to do? the idea of drilling holes in my d60 doesn't make me happy. has anyone done this before is it safe? /forums/images/graemlins/thinking.gif
    1.5 inch is what i really wanted but i wanted to stay away from add-a-leafs because they add height to my ride. /forums/images/graemlins/dunno.gif what can i say i like my ride height , i just want more flex and longer wheel base.
  10. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Go with 52's in the front and reversed 56's in the rear with shims for pinion angle. Or you could use the ORD zero rates in the front to move your axel forward then use a tapered zero rate in the rear to help correct your pinion angle and help keep the ride level. You can put the zero rates in centered in the rear or use them to move your axle farther back if you'd like. Or, I think you could use the zero rates in the front and shim the rear with longer shackles to correct for ride height, this should help stop the pinion from rotating down when the rear springs droop because of the longer front (front of the rear spring) arch.
  11. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    tappered zero rate was allready figured on for the rear to keep driveline angle on track and ride hieght i forgot to mention this in the last post. i still use the hard top so a 1 inch block is needed in the rear to just keep it level. i figured zero rates would be perfect to for ride and driveline angle.
    the front is another story. /forums/images/graemlins/shame.gif i want to stay away from zero rate's, the 6 inch springs are more than enough hieght for me. so far the rear 52 inch springs up front sound the best but i was just e-mailed that 6 inch lift rears up front only become 4 inch actual lift and spacers are needed to make up the space lost by the different bushing thickness (1/4 inch spacer each side of bushing) this makes sence.
    /forums/images/graemlins/1zhelp.gif or is there a poly bushing 3 1/2 inch wide with a width of 2 1/2 inches between the shoulders out there that will fit a stock type spring eye or tuff country spring eye of a rear gm spring /forums/images/graemlins/thinking.gif
  12. fwdjunky
    Oct 12, 2003
    499
    Maricopa, AZ
    I believe that stock 52's moved to the front net 4-6 inches lift (varies a little according to what I've read here), so a set of 2 inch 52's should net you at least 6 inches up front. Differences in bushing width can be dealt with with new shackles or spacers. Lots of good info and pics in this thread
    http://coloradok5.com/forums/showflat.php/Cat/0/Number/1106200/page/0/view/collapsed/sb/5/o/all/fpart/1/vc/1
    He also has basically the same thread on the Pirate chevy forum.
    Hope that helps! Rich
    web page
  13. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    thanks for the info.
    zcar is mentioned in there he is the one that e-mailed me but he didn't move the piviot shackle (rear shackle on the front spring ) he just moved the font shackle bracket to the front of the radiator core support mont (body mount). so the thread just confused my theory. but good info. to think about. it brings about new idea's.
    /forums/images/graemlins/doah.gif i was trying to use my 6 inch lift 52" springs for the front but i sure don't need a 12" lift. /forums/images/graemlins/tongue.gif or i use a 4" shackle flip in the rear and 8" lift springs and hugh tractor tires. /forums/images/graemlins/ignore.gif
    that's to big /forums/images/graemlins/whistling.gif
  14. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    anymore ways to get 1"-2" further out with the front axle? /forums/images/graemlins/ears.gif
