Relocating spring pearches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by carolina custom, Jul 6, 2002.
  1. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I am going to move the spring pearches and shock mounts on my 14b ff. How much heat can I put into the axle tubes? Can I cut them off with a torch and grind flat. Do I need to cool them off pereodicaly during welding? How about the seals?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I think a plasma cutter would work better but then again I have never tried it this way.
    I did one the old fashioned way...4" grinder, BFH and lots of elbow grease. /forums/images/icons/wink.gif
  3. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    My plasam cutter wont work until I get the three phase hooked up /forums/images/icons/frown.gif . Any one had any trouble with overheating the tubes or melting seals?
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I didn't have to relocate the spring perches on my 14b, but I did have to re-do the shock mounts. Cut the old ones off with a plasma cutter, ground the tube smooth, did some slight mods to the stock mounts that I cut off, and rewelded them on with a MIG welder. I didn't let anything cool or anything...If your just workin on the spring perches and/or shock mounts, Your far enuff away from any seals that you won't have any worries. If you use an Oxy/Actelyne torch,you might want to cut alittle then cool off, cut alittle, cool off.....Just because a torch puts out alot more heat. Try to get ahold of a plasma, or like Wes said....Do it the old fashioned way.....Grinder, cold chisel, and a BFH. /forums/images/icons/smile.gif
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I just came inside from doing mine and a grinder did the trick great!! Just as easy and I didn't have too woory about a thing. Get about 6 cutting blades and two good grinding ones and you'll be set!
  6. fbsadmin
    fbsadmin Registered Member
    May 28, 2002
    12
    I torched off the spring perches and shock mounts of a junk yard 14-bolt, ground it smooth, and welded new ones on. The axle was fine throughout the process and works great on the trail.
  7. cityfarmer2
    cityfarmer2 Guest
    Anyone know where to get new perches?
