Relocating spring preches
Discussion in 'The Garage' started by smokkey1, Mar 27, 2005.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Any tips on doing this? I already have the old ones removed and bought some new ones.
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    measure, measure and measure again, then check your angles, hell maybe even bolt the axle in the truck with the spring perches not welded on to get the ideal pinion angle.
  3. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    my pinion angle is pretty good right now. should I set the angle of the preches the same as the pinion?
  4. zcarczar
    Feb 10, 2002
    2,495
    Well it depends what kind of driveshaft you have, if CV point the pinion in line with the driveshaft, if not you want the pinion and t-case output to be parallel.
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    whatever comes stock on an 90' burb.
    so nobody has relocated spring preches before??? btw it's an 14FF...
  6. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    You should have measured the angle of the old perches relative to the Pinion before you cut them off and then glued the new ones on at the same relative angle. Now your screwed! Just kidding… The best way to do it is to install the axle with the new perches loose, and then rotate the axle housing until you get it centered side to side and have the correct pinion angle, then glue it up.
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I know, I though of that after I'd cut them off. well I'll just wait till I get the locker and the rest of the parts for the disk brake conversion. then weld up the perches
  8. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    That's how I did mine. I got my D70 all mounted up, made sure the axle was centered, the perches were at their proper center to center distance, and the pinion angle all set, then I tacked it in, took it all apart and did the final weld with it off the vehicle. I bought some regular nuts for my u-bolts to make it easier to spin them on and off for the install and subsequent removal of the axle. It takes forever to spin those nylock nuts on/off, so I only switched to those for the final install.
  9. fliptuner
    fliptuner Registered Member
    Apr 20, 2004
    16
    B.C., Canada
  10. dark eternal
    dark eternal Registered Member
    Jan 15, 2004
    22
    Dallas, Tx
    set the pinion 1-2 degrees low to compensate for axle wrap under power. Unless you have a link setup you DO haver some axle wrap.
