Remedial 14-bolt lesson please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Boy, Sep 23, 2001.
  1. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Every other post I see is 14 bolt this and 14 bolt that. Well I figured I should get in on the fun, lol. I'm swapping in a 3.73 12-bolt in my '82 w /31"s. So I figured I'd drop the pukey 2.73 12-bolt in my '81 w/32"s.
    I have noooo idea what half the talk is about these.
    What's the difference between a full and semi-floating axle?
    What kinda trucks had what?
    How can I tell?
    Which do I want?
    I have 10-bolt front with 6 lugs and 15" rim, do I have to convert that to 8 lug 16" rim or can I do something to the back.
    I have a good selection out my uncle's so for free I figured why not?
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Full floaters don't use the shafts to support the weight of the vehicle like semi floaters do. This takes a considerable amount of strain off the shafts. They also use two bearings per side as opposed to just one per side in the semi floaters.
    Your frontend is a full floater, your rear is semi floater.
    Most all big rigs and heavy equipment use full floaters.
    Poundin' the ol "pavment"!
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Like red dwarf said, the weight of the vehicle rides on bearings instead of the axle. Also, there is no c clip that holds the shafts in, but to get the drums off you have to pull the shafts out, then take the big bolt off the spindle that holds the drums on. Personally, I have the 14 bolt ff because of it's superior strength. The only disadvantage is that you loose some ground clearance, but i really don't care. Also, the detroit is only about $320, and you get bigger brakes. For converting the front, you don't have to, but you would have to carry 2 different spares. Hope some of this helps. Later - Doug
    Doug Krebs
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Well, the difference between the semi and full floaters has already been covered. I believe the 14Semi axles started in the early '80's, but Im not positive. I know my 79 had a 14 Full floater. Personally, Id go with the 14 FF. Do it once, do it right. As far as the front, you can convert it to 8 lug(so you dont have to carry 2 spares), and run 15" rims(although you must grind the calipers) so you can use your old tires.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Is that to say that the front 10 bolt dana44 can handle the stress just fine? Are we talking a 1/2 ton Dana44 or a 3/4 ton?
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    A 10 bolt or D44 will take alot of abuse up front with upgraded shafts, etc. While not the meatiest axle on the planet, they're great for part time 4 wheeling and every day driving. Personally I don't see a reason at all to swap them out, unless you are into the really extreme rock crawling, or running 44"s.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Throw all dana 44's 6 or 8 lug in the dumpster!!!Unless you never intend on climbing a rock or stay on the street 95% of the time or only run 33" tires YOU WILL BREAK SOMETHING!!!!
    I just broke the carrier in half , and thats after replacing the stub shaft on the pass.side and the u-joint and long shaft in the drivers side!!!!!!!NOT ENOUGH BEEF
  8. KrebsATM02
    Mar 21, 2000
    553
    Not that i'm in love with my 10 bolt, but i haven't broken anything yet. I run 35x14.5x16.5 SSR's and I'm not a pussy about driving my k-5. I have a converted 8 lug front, and it does nothing for the strength of the axle, just so i don't have to have 2 spares. I also have an eaton posi. I'm not saying that i won't break anything either, and i'm getting a 60 in the summer when i upgrade to 42's. Later - Doug
    Doug Krebs
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also if you run 15" wheels on a 8 lug Dana 44 or a 60 they will have to be steel. And you will have to grind the calipers to clear.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
