Remington 870 mounted to M4....
Discussion in 'The Lounge' started by sled_dog, May 25, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My initial reaction, "badass".
    Let it sink in and think again.... "that has to kick like a mule, and I can't see it possibly being effective in close range combat, and useless at range..."
  2. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    LOOKS LIKE A 'CHOP.....not very ergonomic to reach the shotgun...
  3. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Ahem... yes, it kicks like a mule... about as hard as an M203 grenade launcher... you use the magazine as a pistol grip to fire it. As for combat effectiveness... If you had just entered a building you knew to be full of insurgents, and you knew that behind the wall you were looking at with 3 armed bastards turning your way were 5 children huddled in fear, would you:
    A. Fire the .223 round through your target, through the wall, and possibly hit a child....
    -or-
    B. Fire the 00 buckshot scatter gun underneath and make sure none of your projectiles get close to the scared kids... meanwhile blowing your enemy to smitherines...
    It's not designed for "range" combat... it is designed for urban warfare... there used to be a guy on a fireteam who always packed the 870 riot gun by itself... now they can put the firing parts under an M4 or M16 instead of a nade launcher... allowing the Shotgunner to have a range weapon AND a riot gun. I should mention however, that the M203 also has a shotgun shell available, but the cost outweighs the benefit... and it kicks like 2 mules. Personally, I'll take an M4 and a M1911 or M9 silenced over a double gun.
    On another side note, the barrel length of that shotgun is about 10 inches... which means it would miss a squirrel at 20 yards, but be GREAT for a 5-10 foot shot indoors.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    have you handled one? How do you accurately handle it when using the .223? Hold the shotgun?
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Not a new idea. The Indian in Predator carried a similiar setup :D
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I wouldn't think it would kick too bad considering how much it has to weigh
    It's be nice if someone researched enough to integrate them more ergonomically
  8. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    Maybe the 870 is for breaching doors? Although the M4's barrel looks to be kinda in the way for that....Ahh **** it, I'd rock that gun(s).
  9. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    All that PhoenixZorn said...
    12GA CQB tool for Marines, LAPD SWAT in South Central L.A.
    I could work it with practice.
    I want one. :D
  10. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    However, there is a reason that most urban law enforcement entry teams don't usually take a shotgun along. They are notoriously inaccurate. Most urban entry teams rely on a sub gun, like an H&K MP5 in 9mm, G36C in 5.56, Colt M4 Commando in 5.56, etc. Frankly, in a U.S. setting a Remington 870 with 3 inch magnum shells sporting OO buck isn't going to help you stay away from penetrating flimsy sheetrock, or sometimes even a person. Most SWAT teams rely on shot placement instead of the round to protect them from potential collateral damage. However, if I was in Iraq, or similar, I would probably be less concerned with "innocents" and the 870 would be a good option. There is certainly less media scrutiny overseas and determining "non-combatants" is a bit fuzzier.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    most shotguns are plenty accurate at close range. I know on TV a guy shoots a legal bbl length shotty and gets a 3' wide "circle of death" pattern at 10 feet... but all the shotguns Ive ever shot were a hell of a lot tighter-patterned than that in normal close quarters combat distances.
    j
  12. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Well, I beg to differ on the definition of accurate then. A person proficient with an MP5 is going to fair a lot better than the person proficient with a 12 guage at any range in shot placement. a 9mm or 5.56 round is usually going to end up exactly where you aim it. A 00 buck round is going to vary every shot. Try bench resting an M4 and pump round after round into a target. What do you get? a very small hole in the same place. Bench rest an 870 and pump several rounds and you'll see the pattern change every time. As I said, most every SWAT team uses a 9mm, .40, .223, etc. for their entries when they are going to engage a bad guy. If you don't particularly care where the rounds end up, a shotgun is quite effective. There are even LE agencies that go as far as prohibiting officers from taking a shotgun indoors on a call.
