Remote oil filter location?
Discussion in 'The Garage' started by RingMaster4x4, Dec 29, 2004.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I bought a oil filter relocation kit from summit, and I am trying to decied where to put it. I thought about putting it up in the motor compartment, but I am worried about getting air in the line from being above the motor. Should this be a worry or not? Thanks for your time. :confused:
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I got a dual filter setup on my 496. I got my lines run from the stock 1qt oil filter, up the lines, to dual 2 qts, from there to my 6 pass oil cooler, then back to the block. I mounted the filters to a piece of aluminum plate, which is bolted to the core support, where the stock charcoal canister was on the drivers side. Relocated the canister to the other side. I might have a pic in my webshots in the engine album, but I honestly dont remember.
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    So no worries, or problems? I heard that there is a check vavle or something in some new trucks.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i got no problems, cant see as there would be, if the oil drained back, it would just go to the pan, and then it would start pumping up through the lines, but there would be enough extra in the pan to do that.
    No worries w/ mine.
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    cool thanks.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    its done in marine applications all the time.. Mercs have it as high as the carb...
