Remote Solinoid...what else do I need to do?
Discussion in 'The Garage' started by LKJR, Aug 23, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ok I've decided to do this remote solinoid. I"ve mounted it, connected the battery cable on both sides like I"m supposed to. Removed the wires (S&P?) from the old solinoid and hooked them up on the new one. Is there something I"m missing? I noticed the other post saying something about a small metal piece across some posts? Do I need to connect the old S&P posts?
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here ya go, this should help.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    you must connect the big battery cable stud and the s terminal stud on the starter with a piece of metal.
    Blake
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    well I got it all hooked up, thanks for the help, but it didn't seem to help the starting problem..... maybe I need to look into the heat shield thing...anyone have one laying around?
  5. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    buy a starter blanket. i did this when i put my remote solinoid on. take you're starter out and cut and wrap it in the blanket. make sure to tuck it away from you're post's. mine came with zip tyes to hold it on but i got some big hose clamp's and clamped it on. then put it back in and hook up you're wire.
    i did this to my BB with hooker header's, my header's are about 1/2" or less away from starter so factory heat sheild would not fit.
    i have not had any hot start problem's since.
    dave
