remote start w/carb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Oct 1, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    is this possible?
    sometimes i turn the key and she fires right up, other times i gotta ease on the gas....but has anyone done this successfully?
  2. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    not ever reccommended...I have one on my tahoe. Requires extensive electrical mods...mine will
    -crank on/off with remote
    -stay on for 12 or 30 or 60 mins then cut off
    -will cut off if u hit the brakes, rev the motor b4 you turn key
    -can keep truck runnin, take key out, arm alarm leave truck
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    They work on a motor that will fire up without peddle assistance, A friend of mine has it on his carbed 355. They aren't that hard to wire, supposedly.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'd think they would work on electric choke carbs.
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    All the carbs I've worked on require a little throttle to close the choke and set the choke cam, so that wouldn't work.
    I have a Viper 2way remote start alarm but haven't installed it. After looking through the instructions I decided to not bother with the remote start feature. It requires a lot of wiring splices, like fuel pump, ignition, ECM, ac controls (optional), and other stuff that I'd rather not chop up.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just solder your wires. I've installed remote starts before and I never have done it any other way.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    In the winter (when you'd probably most like to use it!) you'll find that the engine won't start. Every carb I've ever had required that you push the throttle to set the choke, then you crank it over. /forums/images/graemlins/frown.gif
    EFI just senses the engine temp and adds more fuel to simulate the correct amount of choke for the conditions. /forums/images/graemlins/cool.gif
  8. tecton
    Dec 1, 2002
    1,553
    WV
    what about setting your idle up a bit to compensate?
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That will not set the choke, nor will it make the accelerator pump shoot any gas down the intake to get the engine to start.
    Remote starters are not for carburated vehicles.
  10. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    since most remote starters include a door lock button for electrics lock. Ive thought about using it to run an actuator mounted to the carb. Something like an idle kicker from a computer controlled carb. Push lock button and this would pump the linkage. I never tried it ,bought a fuel injected dd. /forums/images/graemlins/grin.gif
