Remote start?
Discussion in 'The Garage' started by coptezr, Dec 26, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    my mom got me a kit for christmas will it work on a carbed truck?
  2. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    The remote starter kits I have installed recommend fuel injection I think because most carbed vehicles need to have the choke set by pressing the accelerator.
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    agreed, however, i have seen that some remote starter kits have a optional kit avalible to cycle the throttle linkage
  4. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    put a brick on the gas pedal when you get home at night.:haha: :haha: :haha:
  5. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    286
    161
    Gustine
    What do you think about remote starters set-ups in general? Is it worth any possible reduction in vehicle reliability?
  6. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    I had one for my 99 silverado and i was so much of a pian to get around the passlock 2 or 3 system i said F*ck it.
    first i had to send away for the bypass for the passlock then i had to muti meter all kinds of wires and figure out what resistance then i had to actually set the bypass that had all kinds of switches that had to be in a certain order for it to work..
    It also needed me to hook up all kinds of relays and stuff
    the furthest i got with it was having it started for like 5 seconds and then it died!
    OVER RATED THEY ARE!:angry1:
    Just imagine that if it started your carbed vehicle and somehow it stalled out for some reason you would be in the same situation before you even had one.
    My k5 doesnt like to stay running by itself you have to hack up your wires to get it to work properly not worth it at all
  7. driney
    Jul 6, 2001
    699
    7
    I'm sure it was a real pain on your 99, but I've installed 3 on late 80's, early 90's fuel injected vehicles and they were pretty straight forward installations. As I recall, I didn't actually cut any wires, the remote starter harness wired in parallel with the various circuits. I did have to buy some extra relays, but everything worked great after I was done.
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    My sister loves hers in her car! I have one for each of my Blazers but haven't dove in to installing them yet!
  9. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Just let me know if you want some help. I have been installing auto electronics for the past 11 years. Happy to say I am done with it as a job since I sold the business earlier this month.
    I wouldn't recomend one on a carbed vehicle. The only feasible way is with a electronic choke. No dangers with it but frustrating if it isn't reliable.
    2High4U what bypass were you trying to use. The key to remote starts and the parts to install them is to get high quality items. I prefer DEI but there are other good brands out there. Stay away from Bulldog and the like. On your 99 silverado you should have had a DEI 556LW which is super simple to install. Only have to cut the pats wire, one end into the module, one out, a few power / ground / and triggers and it will read the factory pats code and duplicate it upon remote start. There is another way to do it by permentely disabling the factory security but I won't get into that because I do not recomend it.
