removable mudflaps???
Discussion in 'The Garage' started by bigbadchev84, Mar 11, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    Well i just got my first warning about mudflaps, i have 9inch suspension lift and 39.5x18 boggers, they stick out quite a bit. well i need mudflaps, but i want something easily removable, anyone else runnig something like this?? any ideas or pics would be greatly appreciated
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    no pics.. but, Go to napa and ask them about their removeble mudflaps ?for Semis, You bolt a little bracket to your frame, Then you slide in a piece of square tubing that is bent like a long L and and the mudflap hangs off of that... Removeable with a simple Hitch style pin.
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    or you can do what I know someone that did...
    if you look in your wheel well there is a hole on each side.. you can slide a rod through....each and put a nut on one side.... and attach mudflaps to that.. hard to explain but im going to make it too once I get a warning... well not even... my wife said we will pay the mudflap ticket as they are horrible....
    just need them when I goto bloomsburg or any car/truck show... I want to go and get ZERO, NADA, NINE, Tickets :cool1:
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    That is the same type of deal I am gonna make. It should be pretty basic and straight forward to do if you have a welder and something to cut metal with. If not, buying the Napa ones might be a good route.
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yea they were pretty cheap... I didnt want to put any work into mudflaps heh... They are ugly as hell but hey. I even put the Napa logo on the outside to make them even more of an eyesore...
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    This sh!t pisses me off - do they ticket the dumb fokers in the gravel trucks that are dropping gravel and rocks??? I get 100 of those instances for 1 of ANY type of car let alone a lifted truck.......
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    These are about the easiest there are. Two holes to mount the bracket to the frame and 1 clip to hold the bar to the bracket. You can have both off in about 20 seconds. It is better to use the bar that hold the mudflaps upsidedown compared to what is in the pic, meaning have it leave the bottom of the bracket and then angle out.
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I been thiking about making a bracket that goes in the hitch receiver. Basically a piece of angle iron attached to a piece of square tubing that goes in the receier. Then attach the mudflaps. Only problem is it would be a PITA to store.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Velcro?
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I used square tubing 1 1/4 screwed the flap to it, I welded a chunk of 1" to the frame and drilled a hole treough bot and use a pin to pin them in, Total cost was under $25
  11. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i did mine exactly like spoolnaround....cheep and effective
