removable top ?....
Discussion in 'The Garage' started by lazerus, Jan 15, 2003.
  1. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    my top is in awful looking condition! I want to repaint and fix it up. I did a search and found lots of info, and also got some more ?s...
    -how do you prepare the fiberglass for painting?
    -i read in a search about the 'fiberglass showing through', how do know if the fiberglass is showing through?
    -do you need special paint?
    -what about a sealer?
    thanks for the help, I am sure these have been answered before-I just couldnt find them in the search
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've never worked with fiberglass befor, but my top is also in rough shape. I'm planning on sanding mine down prior to painting. To be honest with you. I'm serously thinking going soft top and forgetting about the hard top.
  3. CJeepFreak84
    CJeepFreak84 Registered Member
    Jan 13, 2003
    32
    Northern New Jersey
    My top too is showing it's age. in my opinion a soft top really is the way to go when you figure the top you have now weighs close to 300lbs. Thats ALOT of dead weight. And plus who wouldn't want to roll up the sides real quick and head out to the mountains?
    /forums/images/graemlins/k5.gif --> /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  4. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    I'M PLANNING TO BUY SOFT TOP AFTER I INSTALL A CAGE TO PROTECT MY DOME...
    74 JIMMY 35'S 355/350/203/44/12
    ALL HAIL THE ALMIGHTY SAWZALL /forums/images/graemlins/usaflag.gif
  5. lazerus
    May 13, 2002
    51
    north texas
    hmmmmmmm, soft top?
    I dont like the prices of soft tops, but I could be conveinced!
    -what do yall think about the security factor of the rig? kinda like a conv that you could easily slit with a knife?
    -how do these hold up in strong winds? rain?
    -do they fade?
    -do they flap and make alot of noise?
  6. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Also, how do the soft tops hold up to branches being drug across them? Here in Florida, most of the trails are very tight and lots of branches scrape the sides of the truck while wheeling.
  7. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I have a full top, 1975 blazer. Last summer I removed the top, cleaned it, sanded it with a DA sander, then 600 grit sandpaper, dried it, then painted it in my garage with an HVLP gun. The blazer tops originally had kind of a spackle finish on them and mine was all gone, fortunatley since I would have had to do a lot more sanding. I believe the paint store guy sold me some sealer to apply right before the paint (a good automotive paint store will help you on this).
    I suspect the reason it was painted with the "textured" look is because it is not very smooth in the first place and this hides the ripples. I can see some in my top when looking from above (don't get there very often).
    If you want to do a bang-up job on your top, do the same thing I did, except paint it with the spackle texture. You can do this with an HVLP gun, but I'm not sure if it is a different spray head or just a different setting. I am going to find out cause I plan to paint it with this finish some day.
    The fiberglass sands really nice and if you have a DA sander and an air compressor, it's a piece of cake. Borrow this set-up if you have to. Painting it is pretty easy too if you have the right equipment. Use an HVLP gun and you won't have much overspray - you can do it in your driveway on a not-so-windy day. I just bought a new gun and plan to do some experimenting (The first gun was a cheap HVLP gun that didn't work that well). If I figure out the spackle technique, I'll let you know.
    Good luck.
    ____________________________
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    From my understanding, the Can-Back tops stand up pretty good, and don't flap around much. You can always fold it up for trails. Kinda nice going upen top anyways.
  9. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    can back's are expensive tho, like $850+ expensive just for a soft top, but i can't complain cause its the next thing on my list anyways
  10. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i sanded my full toper and painted it with rustoleum paint, the kind you get in the one gallon jug. i applied it with a small paint roller. it gave me a little texture and it turned out great. that was three years ago and so far no chipping cracking or flaking.
  11. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    my hard top's about ready to get an overhaul too. this is what ive heard is the best way to go:
    1.) sand the top down - no paint, probably want it smooth
    2.) seal it with some fiberglass sealing resin stuff (dont remember the name, someone will chime in. should be available at a marine supply store though)
    3.) let it cure and paint over it
    It may require a few coats, but the resin should keep the fiberglass from flaking /forums/images/graemlins/thumb.gif
  12. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    well soft top wise...i love the can back...i have had it since july...it dosent flap at all...dosent sound any different than with the hard top on..no problems with branches rubbin on it...as for the rain i dont know...i lost my licence in september and havent drove in the rain with it...+ i have no doors right now..
  13. CJeepFreak84
    Jan 13, 2003
    32
    Northern New Jersey
    I'd have to say that getting rid of all that dead weight is worth the money and it's now a one man job when you want to go topless. Certainly there is some regular cleaning that might need to go on to keep the windows looking fresh but other than that... there's nothing to it. can-back would certainly be #1 in my book but there are other manufactures out there that do a good job as well and are much cheaper... it just depends on what you want out of a top... Hard tops are great don't get me wrong... they have a beautiful look to them but i think a soft top is just so flexible in it's applicaions.. and after all on a trail rig it's important that things perform more than one function.. because honestly if u went out on a nice clear day and it starts to rain i don't think you've got that hard top stored on your truck!
    /forums/images/graemlins/truck.gif /forums/images/graemlins/1zhelp.gif
  14. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I know I plan to replace my hardtop with a Specialty Top Co (STC) Fasttrac soft top this spring. With my truck going as high as it will be, I want to shed the weight. I believe Steve runs a Can-Back, but Stephen (ORD) runs a STC top. They both sell them for just over $500. I am sure they hold up just as well as any convertible top would.
    I understand the concern of stuff poking through it off-road, but how many times are you going to be offroad with the top in place? I'm sure there will be a few times, but most of the time I am on tight trails like that, it isn't during inclement weather.
    Just my .02, but I would start saving for a soft top.
