Removal and install of axle yoke, need advise!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, May 4, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    I'm swaping in my 12bolt this weekend, already got the seal for the yoke swap but what I need to know is which methods are ok? Got the nut & yoke off the 10 bolt with a 3/8 ratchet (GULP), but I need to revove the 12bolts now. I remember something about using or not using a impact and damage to ring and pinion. I also need to replace the crush collar, right? Thanks guys, need the help!
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Why are you going to remove the ring gear bolts? If you are going to change the crush sleeve you don't need to remove the ring gear bolts, only the whole carrier assembly with the ring gear still attached.
  3. Nrose07
    Mar 29, 2000
    267
    Salem ,Or
    Ring gear bolts? I'm changing the 12 bolt's yoke to the 10 bolt's larger yoke. Just need to know the proper method as to not damage my ring and pinion.
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You said " but I need to revove the 12bolts now ". I just reread it again and realize you mean you still need to remove the yoke from your 12 bolt diff.
  5. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    you can remove the yoke nut with an impact, but put it back on manually, you shouldn't have to change the crush sleeve, if you don't overtighten it, the setting will stay the same.
    remove the old yoke, replace the seal, install the new yoke, hold the yoke with a pipe wrench and tighten the nut to the recommended torque. you're done. the yoke should turn with a slight drag but not have ANY play in the bearings.
