removal of oem springs bushings
Discussion in 'The Garage' started by **DONOTDELETE**, Dec 23, 2002.
    whats the easiest way to remove oem bushings? im putting in polyurethane, i have been torching wiht me small hand held propane torche, and thats gonna take days to complete. is there an easier way?
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    take a drill and drill all around the bushing and just basicly cut it out..seemed to work well to me...i tried the torch thing too...all it did was make a mess and really dident get anywhere with it
  2. Frankenstien
    Frankenstien 1/2 ton status
    Aug 3, 2002
    167
    Lewisville,TX
    I'm with Chaz i just redid my bushings for the whole suspension drill, drill, and drill some more. Took one of the old metal sleeves and pounded it out. I guess you could use a socket too, make sure you don't what or need that one thou
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I used an air hammer and a pointed bit and a v-shaped bit and slowly, very slowly got it out - what a pain!
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    all ya gotta do is get them burning and let then burn for a couple of mins. them blow them out and drive what left out with a hammer it took me maybe 5 min per end to do mine, then take a sawsall and cut the outer metal sleeve so you cn fold it in and pound it out.
    i found that removing the out sleeve to be the biggest pain of the whole job.
