Removal of undercoating
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Sep 13, 2000.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Ok guys, I have battled with this stuff for 6 months now. It has made working on my car 3 times as hard as normal. The previous owner lived in ohio for 2 years and got this stuff sprayed everywhere. Under body, in the hood, in the doors, all over!!!! It is similar to grease, but doesn't collect dirt. If it gets on you, good luck getting it off, same for driveways, tools and the damn car. The only thing that has gotten some of it off is heat. When I was burning the bushings out of he leaf springs in the rear, the stuff was just falling off. I tried our pressure washer, but it just kind of moves it aside and makes lines in it. So i am thinking steam cleaning would work. Has anyone tried this?? I am located near houston. Any one knows places that do this??? Anyone have any more suggestions to try? Thanks - Doug
    Doug Krebs
  2. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    Hey doug, I have a fair bit of this crap on my 85. It's like tar. And I have found nothing that will remove it. I do know that steam cleaning is futile. The answer is likely in a solvent of some type. I'll look in eastwoods catalog and see what they offer, I couldn't even scrape it off my rear diff cover with a chisel, I just made a bigger mess. I'm buying new fender skirts because of this. I've tried degreaser, easy-off, bug and tar remover, steam, wire wheels (they foul up) sandblasting (sand sticks in it) sanding, all to no avail. I'll keep trying. If you find something that works, let me in on it.
    "who dares wins"
  3. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    I too had this type of product on my blazer thge only thing that seemed to work for me was a wire wheel on my angle grinder. Just slow and tedious!!!
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Maybe try a steam cleaner(hot water, high pressure) with some degreaser added?
  5. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    you might try laquer thinner ,it is very flamable would use it out side and wear a resperator
    the type used for painting cars .you can buy it in five gallon cans at auto body supplier for about
    5 bucks a gallon , use plenty of rags ,rubber gloves ,its nasty stuff but with cut most anything.
    Mrivan..............
  6. archer
    Aug 17, 2000
    136
    tn
    Just a thought, maybe remove some of it and see how it reacts with paint stripper. Some of that stuff that you apply with a brush and it's real thick. I think that'll work.
    "who dares wins"
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    In the new eastwood catalog there is a product to remove undercoating. They are on line at eastwood.com.
