Remove A/C?
Discussion in 'The Garage' started by Magnus88, Jan 10, 2004.
  1. Magnus88
    Magnus88 Registered Member
    Dec 6, 2002
    50
    Nynäshamn, Sweden
    I am in the process of cleaning up my engine compartment, and getting rid of all the unnececarry junk. /forums/images/graemlins/grin.gif
    Since most of the A/C system was removed by some PO i would like to remove the big black box on the firewall to get better acces to the back part of the engine. Will i be able to just unbolt it or are some of the parts reqired for the heating to work?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The only way to get rid of the big black box is to completely remove ALL you A/C-heater stuff and install a complete non-a/c heater unit. Then you'll have a hole in the firewall that will need to be filled up.
  3. Magnus88
    Dec 6, 2002
    50
    Nynäshamn, Sweden
    Ok... thanks!. And there won't be anything sticking out of the hole in the firewall? It will be completely flat when i fill it, right?
  4. dyeager535
    26,975
    NO it won't be flat. It will be FLATTER, but not flat. Blower motor sticks out of the non-AC box, which sticks out off of the firewall maybe 4". (so guessing maybe 6-8" total "stickout")
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah if you still want heater then you must get non a/c system from a donor truck, but as already mentioned, the firewall is different from a/c to non a/c
    if you look againj you will see that the heat blower and such are mounted to the box and you need those to have at least a heater,.
    the next thing different from a/c to non a/c is that the dash pad does not have vents in it for non a/c system, non a/c just has floor and windshield defroster vents and thats all, very basic,'
  6. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I did this to a customers truck, he hated the way it looked. I removed the exterior box and used a sawsall and cut off the area where the condensor was. Made a plate out of aluminum, sealed it up and put the original box back on. Works good, make sure you seal it up good or you will a wet floor.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I converted my Burb from AC to non-AC. Had to fill the old hole in the firewall and make a new one. Got everything from the donor truck.
    Also a good idea to take a piece of cardboard and bolt it to the non-AC firewall and trace the opening onto the cardboard. Now you have a template for cutting your firewall.
    The sound deadener on the inside of your firewall is essentially the heater box gasket. It too has the hole in the wrong place. Mine was trashed so I made up the difference with windshield putty called "Dum-dum" from the local parts counter.
  8. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    U2Slow, are there any issues with using a pre-81 non a/c set up on a 81+ body? I figure the control head will "look" different but will the box itself will fit the firewall (after I modify the hole)?
    TIA! /forums/images/graemlins/thumb.gif
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    I'm not sure on 80-older heaters... I was in a pinch so I stole the non-AC heater from my crewcab! /forums/images/graemlins/crazy.gif
    The 80-older stuff looks the same from what I can remember. The heater cores are the same anyways.
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    whatever you do don't forget to cut a new hole for air to blow through. I did the conversion twice now and the first time I forgot to cut the hole. DOH!!!!
  11. Magnus88
    Dec 6, 2002
    50
    Nynäshamn, Sweden
    Ok, thanks a lot guys! I'll see if i can get my dirty hands on a complete non a/c setup.
    BTW, i have been haveing problems with the tranny since i got it. Shifting hard itno 2nd, feeling like a tired old dog on acceleration. Today i adjusted the T.V. cable and... presto-changeo!!! /forums/images/graemlins/rotfl.gif
    I just thought the 6.2L was that tired but now it feels like a completeley different engine! A 3 minute fix and it made all the difference in the world.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    axle ratio affects acceleration rate directly, and cable adjustment will change shift point, pull it too far and it will shift later and harder, opposite occurs when cable is too loose, you want trannny to shift quicker in order to let clutch pack discs last a long life and fluid to stay clean
