Remove my top?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen_md, Apr 2, 2002.
  1. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    Got a 90 k5 and looking to take off the top can I take off the top? The bolts that hold it on are like a torx head with a little thing in the middle. Any help would be appreciated.
  2. dyeager535
    26,982
    191
    They are anti-tamper torx. You can find them, they are around. Not sure of aize, they could be the "oddball" t-47 if GM was trying to keep people from removing the bolts, which they were. I asume the seatbelts on the topper are held in the same way.
  3. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    Yup, you sure can take it off. As far as the bolts go.... you have two options. You can either buy a driver that will fit the stock "security" bolts (they DO make them - I have one) or you can take the bolts out however possible (vise grips come to mind) and replace them with a normal hex head style. Also, there are two additional bolts mounted upside down towards the rear corners of the truck that are hidden by the side panels. It's possible to access this bolt by removing the speakers and using an extension or by partially removing the whole side panel. Once you get those last two upside down bolts out, leave 'em out permanently. They're useless. And that's it!
  4. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    It is a T-40-S
  5. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I usually use a lot of alcohol and sweet-talking to get a top off....oh...you meant on the truck! Same method, different application.
  6. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    I have an 87 and I want to take the top of then get a soft top for the summer, but everyone tells me not to becuase when you put the hardtop back on it leaks. Anybody got any advice.
  7. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    oh my god thats funny as he!!
    leave it to yall to make me smile after a crappy day
    Later
  8. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    take it off slow and dont tear any of the weatherstripping and you should be fine...
    Later
  9. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I always heard about the hard top leaking as well, but took it off anyway. I've had it on and off on my 86 about 15 different times now with no leaks. I'm thinking maybe the old style with the full removable tops may have leaked and thats what people talk about?? I always heard the same thing too. When you put it back on tighten the cab bolts before the bed rail ones, this will pull it tighter to the cab.
  10. keeferk5
    keeferk5 Registered Member
    Sep 9, 2001
    54
    northern illinois
    If you are careful taking it off it won't leak when you put it back on.( mines been coming off and going back on for 5 years and never leaks). I am pretty sure that Ford started that rumour because the Bronco's leak so bad.
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    When I take my top off I spray the weatherstripping with windex or 409, something like that to make it a little wet. Things don't tear as easily
