Remove rust with a battery charger and baking soda
Discussion in 'The Garage' started by Leper, Feb 8, 2007.
  1. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Did anyone see the show on "Trucks" where they used a 3a battery charger and a bucket with water and baking soda to completely remove rust from parts?
    I am trying to get the ratio of baking soda to water, so that I can try it myself.
  2. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I do not remember exactly but it was a small amount of baking soda. Something like a cup per 5 gal. of clean water. It should be on again Saturday though.:wink1:
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I did see it but only the last few secs of that tech tip. I thought it was some chemical they bought.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
  5. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I wonder if this will work on a large scale like a swimming pool? Then I could just push my blazer in and winch it out a few days later, good as new:doah: :haha: .
  6. bear76
    Oct 16, 2005
    1,065
    here
    wait....:thinking:
  7. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Thanks guys. Looks like I will be putting some rebar in a 30 gallon trash can and dumping in some parts this weekend.
  8. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    read my mind!..
    I had the same thoughts!..but 3 days later ,I bet all that would be left of my truck would be the tires!.:doah: ....they are about the only things on it without at least SOME rust on it!...:rolleyes:
    Must work kind of like electro-plating something,only in reverse!..I've seen guys on "treasure hunt" shows use similar devices, to "clean" old coins and other precious metal objects that sat on the ocean floor for centuries,made them look like new.....
    I saw a "corrosion inhibitor" device on a Nissan truck that came in my friends shop recently--it hooks to the battery,and supposedly prevents rust and corrosion..the truck was pretty rust free!..I've seen them advertised in J.C. Whitney before,but never saw one for real..I guess many bridges and ships use the same principle for corrosion protection..works like those "sacraficial anodes" they put in radiators,and on metal objects submerged in salt water I guess...:crazy:
  9. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I've used this technique for a while now. Did every thing on my D60 that would unbolt, used my shopvac tub as a container. It knocks off even the scale rust. After the "dip" just scrub the black deposit off with detergent and a bristle brush and paint, beats sandblasting and grinding. I use one tablespoon of Red Devil drain cleaner (sodium hydroxide) to one gallon of water. biggest thing I've done was a D60 tierod in a piece of 4" PVC pipe stood on end with a cap on one end. Everything came clean over nite so by the weekend everything was ready for paint.
  10. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    I have had great results using a 1/2 to 1 cup of laundry soda to 5 gallons of water. I use 2 pieces of big rebar in the bucket and a 10 amp batt charger. I now have a 100 amp charger but am skeered to try it for this.:D
  11. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I posted a link and pics of a way to do a whole frame. It used plastic tarp and stuff. It was a year or more ago though.
  13. Steve GMC
    Dec 3, 2005
    247
    SICK
    how long did it take?
