Remove Wing Window Lock???
Discussion in 'The Garage' started by bigbadchev84, Feb 18, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    How Do I Remove The Lock From My Wing Window?
  2. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Ditto, I need to know as well.
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hit the roll pin out of the handle, the handle comes off, they there is a torx screw that goes in the outer portion, take the screw out and everything is off the wing.
    Blake
  4. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    If you look at the lock near the glass you will see a very small roll pin. just punch it out carefully. Next the handle, a spring and a small thrust washer just pull off to expose a nut. Not sure of the size, but that's all there is to it.:)
