Removed about 500 lbs from my Dually
Discussion in 'The Garage' started by Russ, Dec 19, 2005.
  1. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I removed about 500 lbs from my dually this weekend. Took the little TBI 350 out so I could install the TBI 489.
    Russ
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    mmmmmmmmmmmmm big block mmmmmmmmmmmm
  3. sandracer799
    sandracer799 1/2 ton status
    Feb 10, 2004
    834
    Richmond,Virginia
    That sure is PURTY!
  4. Ten_Bucks
    Ten_Bucks 1/2 ton status Premium Member
    Dec 9, 2004
    892
    46
    Placerville, California
    Good thinking on putting a big block in your dually. A small block in a 1 ton pickup makes as much sense to me as putting an elevator in an outhouse.
  5. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I agree, I never understand the philosophy behind a small block in a crewcab dually pickup. They had to put 4.56 gears in it to make up for the engine, so that killed any fuel savings there may have been. I am definitely looking forward to the torque increase with the 489.
    Russ
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Outta be able to lay 4 black rubber bands. ??removed the hood, radiator but not the core support, take-off the fr wheels to kneal as low as poss?? I'm doing my swap starting 12/26 @ o'dark-thirty.
  7. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Looking good. :thumb:
  8. Ten_Bucks
    Dec 9, 2004
    892
    46
    Yeah, big block Chevy engines are the kings of torque as far as gas engines are concerned. If you'd want any more torque, you'd have to go diesel power.
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I dunno about that, caddies are up there.
  10. Ten_Bucks
    Dec 9, 2004
    892
    46
    You're right, so let me rephrase. BBCs are ONE OF the kings of torque as far as gas engines are concerned.
  11. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    I had planned to remove the whole front clip, but decided to try leaving it in place first and so far everything has gone real easy with the removal. I still may wind up pulling more of the front end if the install gets difficult. I hope to put the big block in over the next couple of days.
    Russ
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  13. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    not as bad as....
    I agree,a crew cabs smallest engine option should be a 454!..:D
    I worked on several late 80's crew cabs owned by Amtrak..they used them as maintenence crew trucks for railroad track maintenence and repair..they were 4x4's,and had the steel train wheels that allowed them to be driven on the tracks!..hydraulically operated..the guys said they could go 65- 75 mph on the tracks--with no hands!:eek1: ...they were SO heavy,the 10,000 lb lift strained to pick them up when we'd do oil and tire changes..and I almost died laughing when I opened the hood on one,expecting to see a thumping 454 BBC to haul all that weight..,or maybe a 6.2 diesel..----
    To my suprise,there was a rather boney looking 292 straight six in it!...:eek1: ---I asked the guy how it drove..he said "its a good thing it has that "granny low" manual tranny..it NEEDS it!..if I have 6 guys and tools in it,I'm lucky if it will hit 75 MPH,on level ground!..I get passed by VW busses going uphill!..but they never die!..
    They all had well over 150,000 miles,and my friend said he had done all the maintenence on them since new..only major failure on one was a blown head gasket!..but what a joke,a truck like that needs all the power it can get!..:rolleyes: :crazy: ..
  14. Ten_Bucks
    Dec 9, 2004
    892
    46
    Yeah, that idea is just wrong. That thing should have AT LEAST a 454 in it. If not a 454, a 6.2 diesel would be the next best choice.
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I was wondering cause friends say "take off the clip" but '85 factory man only says hood, rad, and all the pulleys; but looks like you pulled SBC with pulleys on. I suspect BBC install might req. pulleys off. I'll return with results on my SBC swap @ 12/28. Aint nothing like a fresh motor, especially a HiPo. Thanks Russ.:D
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yea, that old Blue Flame can be built w a low & fat torque curve, I'd bet the IL6+SM465 (no doubler) make a neat ultralight truggy. Hmmmm, I smell wood burning.:hack: :weld: :grind: :xmas:
  17. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Update on Progress
    Enlisted the help of my kids today and put the big block in. Everything went extremely easy. I am down to the point of hooking up wires and hoses and then hoping it starts.
    Russ
  18. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Looks damn good!
  19. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    oooolala looks nice!!!!!!!!!!!!!
    i also am confused by the engine choices by chevy. a year or two back i bought a 78 1 ton cab and chassis with a 292 straight six. whats with that? four wheel drive and 4.56 gears didnt help this beast along at all. it was a line truck with 1000lbs of hydraulic arms in the back to lift spools os cable. just odd to me.
  20. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Russ that motor is just plain secksy!!
    How much different are the hose connections between the old and new a/c compressors? Also, what throttle body are you running? Is it a modified OE 454 unit or...?
    What kind of hp/tq numbers are you hoping for from the motor?
    How's the rest of the truck going?
