Removed stock air cleaner,now runs rough
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Jun 23, 2004.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    I took off the stock air cleaner on my 87 burb and replaced it with a open element filter.Of course there is nowhere to put that tube that connected to the stock one.
    At first it died out a couple of times,then it ran ok.
    I took a 1100 mile trip and on the way back it would die for just a half second.Enough to where the criuse control would turn off and the fasten seatbelt light would come on.But it wouldint fully die out.
    Now ,it happens more frequently.
    The motor is mildly built and likes the extra air.But you can hear the air blowing from where the tube was.
    Should I take the belt off the air pump? Will that help this?
    Any other ideas?
    Thanks in advance
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the hose that used to go to the air cleaner where does it come from? Try drilling a hole in the bottom of the airfilter bottom retainer thats in between the filter and carb and stick the hose in there.Your carb might need to be rebuilt too.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Exactly . Actually most aftermarket air cleaner bases have the knockout there you remove to attach a hose . And also anytime you change intake and exhaust , you must readjust the carb , no way around it if you want it right /forums/images/graemlins/k5.gif
  4. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    Thanks for the qiuck responses,This a TBI motor,so the computer does all that right? Do I really need the airpump?
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do I really need the airpump ?
    Do you really need to pass emissions ?
    BTW I am almost ready for bed , didn't catch it was an 87 with tbi . I'm still stuck on carbs for now /forums/images/graemlins/k5.gif
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Why did you go to an open element with a TBI? You will make more power if you leave it stock. The stock system will flow more air than the TB can handle. The cooler air drawn from the front will make more power than the hot air from inside the engine compartment.
    Is the tube you are talking about the vent hose for the PVC system? If it is. You need to hook it up. Your PVC valve wont work right and cause driveability problems by making the MAP sensor get wrong readings. Also it can suck un filtered dirty air into the crankcase.
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I agree, you need to slap the stock stuff back on. You'll get cooler air that way and cool air means more power. If you think your having problems now, wait until it gets cold...it's gonna be a bitch... /forums/images/graemlins/doah.gif /forums/images/graemlins/grin.gif
  8. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    Fuel injected engines are much more sensitive to air intake temps.
    I wish I'd never put the open element air cleaner on my truck, and I have a carb. Now I'm stuck with a $45 air filter I hate to loose going back to stock type air cleaner.
  9. muddbogg89
    Mar 19, 2002
    97
    Chicago(suburbs)
    ok I just put the stock one back on.It had died out completly on me twice today.
    It's strange that the open element filter didint affect my old 89 blazer at all,it's actually the cleaner from it.Hopefully it should go back to normal.Although I will miss the growl it had with the open element.
    Thanks Guys
