REMOVING 1 LEAF FROM SPRING PACK?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLUESMAN, Nov 12, 2001.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Some you know that I wanted to go with a 2" lift on my K/5,well I ahve decided to go with a 4".Now my Q...Can i remove one of the leafs in the "pack" to reduce the lift?And which leaf?I've ordered a pair of Rough Country's.....so they are rated fairly stiff.I still plan on cutting the Frt. fenders flat w/ the whellwells.Anyone experiment with removing leafs and which one would be better?Thanks.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i would assume the bottom leaf. but that's all i got sorry.
    people that get good mileage aren't having any fun!
    scott,
    1989 GMC suburban 3/4t 4" lift finally rollin on 36" swampers, tbi350, th350, np241
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    If you remove the spring pack center bolt and have the springs come to a rest(USE C-CLAMPS DON'T JUST TAKE THE NUT OFF) you will notice some of the leafs are straight and some are curved. To get less of an arch you would need to remove a curved spring. It maybe the bottom the one or the one right above it.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  4. BLUESMAN
    Oct 3, 2001
    951
    Yeah that's what I thought.i figure the top two leafs will be "military" wrapped leafs and either the middle leaf or the second to bottom would be the one to remove.I will see at the end of the week.Anyone know what degree axle shim should go in the frt?I'll be running the modified 4" springs(hopefully 3") with ORD's 1" longer shackles.I have a 4 degree shim that I can try.Thanks.
