removing 12 bolt axle shafts
Discussion in 'The Garage' started by tmanofcali, May 18, 2003.
  1. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    what all do i need to do to remove the axle shafts from the rear end. i already have the brakes and all that off. just what do i have to remove or loosen inside the pumpkin?
    thanks, todd
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Take the cover off, take out the cross pin, you will see the end of the shafts with the c-clips. Usually when you push in the shaft a little, the c-clip will just fall off.
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I went over to his house and did it...I had to remember a 12 bolt...lol
  4. SHINTON
    SHINTON 1/2 ton status
    Dec 26, 2001
    148
    Kernersville, NC
    Hmm, any pictures of the cross pin or C clip? I took the cover off this weekend and was eyeballing it for a couple minutes. (Spare axle)
    I am trying to remove the carrier for a Lock Right install, I just helped do one on a Dana 30 (Heep TJ) I will try to get a light down in there to see if I can see this infamous crosspin. (Cross pin is on the diff end or back at the brakes end?)
    Any other tips for the Lock Right install? I have seen several writeups for the Dana 44 and Dana 30, but not a good one for the Corp 12 bolt? Link?
    Sam Hinton
  5. dyeager535
    26,980
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
