removing 14bff carrier
Discussion in 'The Garage' started by mostwanted, Jan 25, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    If I remove the carrier as a "unit", do I have to re setup the gears? I am hopeing to get the 14bolt welded.
    What about the front? No welding, I just need to clean out the center section well.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    On a 14FF just need to reset the BL, for the front just reinstall with the shims in the original loactions (If a 10 bolt), for a D60 front the shims are under the pressed on carrier bearings so you can't mess them up.
  3. goldwing2000
    goldwing2000 Guest
    If you count the number revolutions you back off the side bearing adjusters and put them back the exact same amount, you should be all set.
    Check the backlash before you start, write the number down, and just double-check it when you put everything back together.
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    when i put my locker in, i just put everything back the same way i took it out, same number of turns on the bolts, etc, no problems.
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Me too, a few times. But that doesn't mean its right.
