removing a/c
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tmanofcali, Mar 26, 2002.
  1. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    has anyone ever removed the a/c from thier first gen? what all is involved? do i have to change the heater core to a non a/c one or can i still use the a/c one? can anyone think of anything that im not thinking of? also when you remove the plastic box...is there just a big hole there that i will have to plug? thanks in advance for your replies.....tmanofcali
  2. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    Haaaa.......Hey Tman, thats exactly what i am doing to the Jimmy at this very moment. I was going to try to go with a Non a/c air box on the firewall but u would have to do some fabbing to make it work. I sawzalled mine so its just covering the 2 holes closest to pass. side, and i will cover the last hole w/ sheetmetal. If i get it done today, i will set up some pics. hope this helps.
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Hey Todd!
    Whatsup man...? I don't have anything to add, since I don't have A/C to begin with.....but I just wanted to say "HI" and see how your new business venture is coming along.... /forums/images/icons/smile.gif
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I dont know if you have the under dash unit or in dash unit, but if you have the under dash ther will be two holes about 1 1/2 round to plug where it goes through the firewall. I dont know about the core. Mine was already out. ?I think it still has the same core. If you have a number on it I iwill look.
    If you have the under dash do you want to get rid of it?
    Nathan
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I have the compressor off mine, and basically the heat works just the same without the A/C. No need to change anything else.
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Definitely different heater cores. I have the A/C core sitting new in a box in my room and it looks different from the non-A/C core that's in my Blazer. I'm going to do the reverse conversion (and I was searching for a 4-speed Blazer without air... Something's wrong here! I already pulled the 4-speed and now I want to put in A/C!).
    Anyhow, if you don't need the A/C control unit that's in the dash, I'd be interested in it. I also need the bracket that bolts to the water pump and supports the compressor and the tab that's mounted to the battery tray.
  7. jeffer
    jeffer 1/2 ton status
    Nov 6, 2000
    113
    Loveland, Colorado
    I have an under dash unit that I am going to be removing. As far as I know, the system is complete. I run without a top in the summer so don't need it and would like to clean up the cab/engine bay. As far as I know, it all works. I've never put a belt on it (had the truck a year and a half.) The system is still sealed, as I pushed the release valve and it's got freon. As soon as I get time it's all coming out and will need to go. Interested?
    Jeff.
  8. Dave_S
    Dave_S Registered Member
    Apr 11, 2001
    56
    Portland, OR
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>Steve... drop me an e-mail. I have a control head that's in excellent condition. Maybe we could work out some kind of trade?
    Dave
  9. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    My truck had factory A/C, and it didn't have the compressor or anything when I got it. All the garbage on the pass. side firewall is still there and my heat still works fine. Although I wish I could either have A/C or get rid of all the A/C stuff since it doesn't work.
    Will
  10. tmanofcali
    Mar 20, 2001
    372
    lodi, ca
    72 thing, thats exactly what i want to do......its just a big ugly box taking up room. in the summer i run topless so it is useless. besides it will open up the engine bay alot and be cleaner looking.
    thanks for all the replies guys!! pics would be cool.
    greg, the business thing is going like old people screw........slow and jerky
    later.......todd
