Removing a gauge cluster with tilt steering......
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ak7, Sep 8, 2002.
  1. ak7
    ak7 Registered Member
    Feb 15, 2002
    57
    Hayward, CA
    Allright. I've got my 72 GMC Jimmy with tilt steering and a 71 Blazer for a parts truck. The Blazer does not have a tilt steering column and the gauge cluster comes out very easy. So I've got it all cleaned up and ready to put into my Jimmy and I can't get the Jimmy's cluster past the tilt column. Has anybody run into this before? What did you do to get the cluster out.
    ak7
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've got tilt steering in my '71 Suburban and when I've swapped clusters, I've had to loosen the 2 bolts that hold the column up to the dash. Dropping the column about 1/4 to 1/2 should be plenty. /forums/images/icons/grin.gif
  3. ak7
    Feb 15, 2002
    57
    Hayward, CA
    Thanks for the info. I actually thought about doing that but I wasn't sure if it would allow the whole shaft to lower at all. I've never installed or removed or done anything with a steering column or shaft before. Thanks again I'll try that in a bit.
    ak7
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You usually have to drop the column a little to get the gauge cluster out even with a non-tilt column.
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I'm painting the inside and was wondering the same, thanks guys
