Removing a leaf from Rough Country 4" Front springs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by atlantak-5er, Dec 29, 2003.
  1. atlantak-5er
    atlantak-5er 1/2 ton status
    Aug 20, 2003
    225
    Atlanta, GA
    Removing a leaf from Rough Country 4\" Front springs?
    I have heard that several people on here have done this to soften the ride. My questions:
    1) Is it safe
    2) Which leaf do you remove?
    3) Will the new set up compare with the the e-z ride of tuff countries?
    4) Am I just being cheap and should just buy a set of 4" TC's?
    BTW I will be running 57" ford springs in the rear and want the front to be as soft.
    Thanks.
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Re: Removing a leaf from Rough Country 4\" Front springs?
    I have the 4" RC as well. I removed the bottem 2 leaves and put in a zero rate. I think it is too soft now. I put in the zero rate hoping to raise it, but the back was higher. I am going to put the bottem leave back and see how that does. /forums/images/graemlins/burb.gif
  3. atlantak-5er
    Aug 20, 2003
    225
    Atlanta, GA
    Did you try just taking the bottom 1 leaf out first? I wonder if this would work.
  4. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    No I just took them both out at once. I did read somewhere that the shorter ones are stiffer than the longer ones.
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I took out the shortest bottom leaf. Rides good now. I lost a little of the lift, but gained it back when I installed the Dana 60 /forums/images/graemlins/thumb.gif
  6. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    How much lift did you lose after removing the bottom leaf?
    I have the 6" and have been thinking about doing this myself.
