Removing ABS on a NBS rig?
Discussion in 'The Garage' started by sled_dog, Jun 9, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I want to remove the ABS on my 97 C2500. Figure its the easiest and cheapest of the mods I need to make for SAS so I might as well make it now. My question is, are the proportioning and metering valve in the ABS motor? I'm figuring on just removing the pump, making lines and coupling to the stock hard lines where they would have coupled with the ABS motor, and for the rear throwing a proportioning valve in line for the future upgrade to rear discs when she gets a 14FF or D60 under the rear. I realize that until I retune the ECM the ABS light will be on of course but that will be reworked when the time comes for engine mods.
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    the proportion valve is bolted to the abs unit. best to just tee the front off the master and install the adjustable in the rear and blead it and be done.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Pull the abs bulb in the cluster.
    ECM will probably set a no communication from ABS code, but may or may not trip light (my guess is not).
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just pull the plug from the abs unit, it wont throw a light and it will still work fine. Thats what i did with my 93.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'd much much rather simplify my underhood setup. ANd mines a 97. Things change, the ABS light would be on for certain and maybe check engine as well. Like I was saying, I'm going to get the TunerCat setup for it so I can disable downstream O2 sensors, change fuel trims, and just all around tune the thing. Plan to fully deconstruct the wiring harness enough to remove the ABS stuff.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    that doesnt work so well- I have my "brake" indicator light come on after a few minutes above 30 mph or so. So what is that?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    it doesn't sense wheel speed sensors most likely because you took the major component of the ABS system out of the loop. Not sure if they go to the ECM or a seperate module for the ABS.
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Wheel speed sensors only go to abs module. One in each front wheel. Uses vehicle speed (driveshaft speed) to pick up rear wheel speed on most GM's. Which, it gets that signal from the ECM/PCM. Some 4WAL (not trucks) have individual wheel speed sensors on the rear.
