Removing and Disassembling Door Vent Windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Apr 1, 2001.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    I'm wondering if anyone has disassembled their door vent windows before. I'd like to remove the glass to do a quality tint job, and wonder if I'd do more damage than good.
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
    http://community.webshots.com/user/beefcake83
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's really more trouble than it's worth. Just use an exacto knife to cut the trim right at the egde of the frame. Then position the tint against the frame before trimming at the back edge of the glass. Do the cutting around the frame edge before you even remove the backing film from the tint. Wet the glass, apply the film, position it and then do the final trimming.
    The main thing you should do to get a quality tint job is to use 3M tint film and make sure that you get all the water out from under the film. A rubber squeegee won't get enough water out. You need to use a hard plastic and keep the tint wet as you squeegee so you don't scratch or tear the film. If you leave water under the film then you'll get bubbles in the film later on. [​IMG]
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    The side track bolts in and I think there is a bolt or two at the bottom of the window.... Not sure how to get the vent window out though..
    I think I agree with Harry.. Or maybe just remove the bottom weather stripping stuff and that way your tint line will be below that!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did that on an old truck and it was a real pain in the a$$. I'de say leave them in.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
