Removing black GM glue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 45acp, Feb 14, 2001.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    I have removed the fuel tank for several other modifications and would like to get rid of the black tar/glue that GM put on the tank. The same stuff is under the carpet inside. How have others gone about removing this stuff? Thanks, Bill
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    There's gotta be a better way of doing this, but what I did to remove the glue under the carpet was I got a scraper with a new blade and sraped it off. It took a while but it worked. You might want to try a wire brush that you can attach to a drill. I thought of that one after I was done........Smart huh.
    MY K-5 DOESN'T LEAK... IT JUST MARKS ITS TERRITORY.
  3. cp87jimmy
    cp87jimmy Registered Member
    99
    Frisco,TX
    I also used a blade scraper when I redid my interior. Be prepared to scrape a few of your knuckles.
    Late, Chris
    GO STARS !!!!
    <A target="_blank" HREF=http://www.cp87jimmy.ck5.com>http://www.cp87jimmy.ck5.com</A>
  4. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I used a wire wheel on a grinder. Works pretty well but is time consuming. I would scrape up as much as possible and then do that. Body filler smells great when you hit it with a wire wheel!!!!!! - Doug
    Doug Krebs
  5. Logan
    Logan Registered Member
    93
    Fournier, Ontario, Canada
    I don't know how much of the stuff is on there, but I had pretty good luck using carpet gum remover (Sprays on, freezes the gum/tar, and it just chips right off!) when I was yanking up the nasty water-trapping vinyl flooring on my old Toyota Pickup. I can't remember the brand name of the stuff, but it was basically a compressed gas of some kind in a spray paint type of can.
    -Al.
