Removing brake rotors on a '97 'burb
Discussion in '1992-Present Chevy & GMC models' started by heavy4x4, Nov 6, 2002.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Removing brake rotors on a \'97 \'burb
    Hey all,
    My dad has a '97 sub, and his rotors need replacing/resurfacing. My question is: What is involved in removing the rotors. Step-by-step would be nice if you have done it. Are any special tools needed (like a spanner nut socket for straight axles)? Sorry if this sounds like a dumb question, but I'm not familiar with the i.f.s. setup. I couldn't even tell you how to take apart the hubs. (Why must it be so different than straight axles /forums/images/graemlins/confused.gif /forums/images/graemlins/angryfire.gif) Thanks in advance.
    Also, he constantly has to have these things resurfaced - which is why he's going to attempt it himself this time. Are there any rotors out there that are more durable which prevent excessive wear/warping (he's getting bad wobble when braking)? The truck doesn't do any towing, nor does it see long periods of braking - like decending hills.
    By the way, I did a search and all I could come up with about the wobble issue was inconsistant torque on lug nuts. Found no information on removal process. Any help is appreciated.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Removing brake rotors on a \'97 \'burb
    I'm pretty sure that all you have to do is remove the caliper and then the rotor will slide right off. It just slips over the wheel studs on IFS trucks. /forums/images/graemlins/cool.gif
  3. heavy4x4
    Aug 28, 2002
    3,270
    Are you serious????!!!!! Good lord that is easy. I wish I would have at least taken a tire off and looked at this.
    Can anybody else confirm this for sure?
    Thanks for the quick response.
  4. chevelless502
    chevelless502 Registered Member
    Jun 5, 2002
    45
    Colchester IL
    Yes, thats all there is to it. Its bordering on a no brainer. You will need a big "Torx" bit to remove the caliper, sorry I cant remember the size. Once you have it off, the rotor should come right off. Sometimes they get alittle rust built up around them and they need a "VERY LIGHT TAP" from a hammer but this is rare. Be sure when you put the wheel back on to use a torque wrench so you dont over tighten the lug nuts and warp the rotor again. If you have any questions feel free to email me. I was a service manager for 4 years and saw alot of them.
    Andy
  5. heavy4x4
    Aug 28, 2002
    3,270
    Thanks a bunch guys.
  6. Joey D
    Joey D Registered Member
    Mar 20, 2002
    42
    Arlington MA
    On my truck I have to remove the caliper, the axle nut, and the 4 bolts on the back side of the spindle to
    remove the hub and rotor as 1 peice. Then press out the wheel studs to separate the rotor from the
    bearing.
    I thought that all 4x4's were the same.
  7. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for your response.
    Does anybody know if this is true for my dad's 1/2 ton 4x4 ifs suburban?
    Now I've got two completely different answers. Which one do I believe/go with?
  8. chevelless502
    Jun 5, 2002
    45
    Colchester IL
    Joey,
    The 3/4 ton and 1 ton models were like that where they had to be removed by taking out the 4 bolts on the back sides but the half tons were just what they call knock off rotors.
    Andy
  9. heavy4x4
    Aug 28, 2002
    3,270
    YESSS!!! Good timing. You just saved me a lot of worry. Thanks.
