Removing Carrier bearings?
Discussion in 'The Garage' started by toy4x4runner, Mar 14, 2006.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    I can't seem to pull the carrier bearings off my D44 Detroit. They're on there good. I have a "gear" puller type tool and it's not touching it. what "tool" do I need?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I usually use a bearing splitter, probably the same thing you have.
    If that does not work I would cut it off with a grinder, just be sure not to cut into the carrier.
    When you think youare almost through the bearing, give it a smack with a chisel and you will see it crack.
  3. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    well I'm trying to set up my gear pattern, so taking on/off would be nice. I didn't try a bearing splittler yet... just the jaw puller.
  4. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    If you're doing a gear set up make a set of "setup" bearings by grinding the inner race so it slides over the carrier.
  5. readymix
    May 30, 2004
    6,706
    26
    Yeah,
    first: the two and three jaw pullers don't really do anything for carrier bearings without ruining the cage
    Second: Do exactly what loafer said.
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Put the bearing splitter under the bearings, then use a two-jaw puller to yank them off. You will have to use something for the puller to seat against on the end of the carrier that is small enough to fit inside the bearing, but big enought to stay on the carrier (a small round cap comes to mind).
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Look on pirate on the gear install tech I am just too lazy to type it here but you can set backlash pretty much the first time if you have a dial indicator and a mag base
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Randy's Ring and Pinion sells a tool for that. It looks like a big power steering pulley tool. http://ring-pinion.com
