Removing cat from exhaust...Good idea?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaBnn3, Nov 22, 2009.
  1. GaBnn3
    GaBnn3 Registered Member
    Jan 2, 2005
    90
    Holyoke, Ma.
    I live in Mass, where my '88 Suburban no longer has to pass emissions. I need to replace the exhaust and wondered if leaving the cat off with affect it either positively or negatively. Any thoughts from the experts? Thanks.
  2. BlazerFarm
    BlazerFarm Texagonian
    Mar 19, 2003
    1,265
    Gresham, Oregon
    I'm pretty sure removing it is against Federal and State law.
    From your own state:
    http://www.mass.gov/legis/laws/mgl/111-142m.htm
    I'm not sure if a muffler shop will even give you an option of not putting a cat back on.
  3. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,356
    Arcadia, MO
    A real inspection station will not pass it. I believe it has to be a 80 or older to not run one
    Unless of course you know a guy
  4. sweetk30
    Nov 1, 2004
    24,892
    175
    horseheads , ny 14845
    to be safe i would ditch that old prob worn out cat.
    then get a nice highflow new name brand replacemnet and instal it.
  5. Jessie James
    Jessie James 1/2 ton status
    Oct 16, 2009
    2,515
    VA
    My Blazer came with no cat (PO removed it) and it made it almost unbearable to drive with the windows down.
    A new cat is only $112 at Advance Auto. You can get a high-flow one for like $175. Why bother taking it off. I just put the new on one my truck and now I can drive with all the windows down and even the tailgate. SO NICE. :bow:
  6. rufusbooth
    rufusbooth 1/2 ton status
    Jun 6, 2006
    525
    Northern California
    Technically it is illegal to remove it based on federal law. Having said that removing it wont hurt anything except your nose. I like driving with the tailgate window open on my truck and you just cant do that without a cat.
    I have a 73 jimmy that never had one from the factory and I put on a pair of them. Although, with the new cat laws in the peoples republic of Kalifornia I think it is illegal for me to add them to my truck. According to the letter of the law there is no application specific cat since my truck never had them. I dont care, It is so much nicer to drive the truck with the cats.
    Cheers,
    Rufus
  7. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,709
    116
    Truckee, CA
    A good high flow cat does not restrict exhaust flow. I'd keep one on there. Really, no reason to harm the environment unnecessarily, and risk getting caught breaking a federal law.
  8. 496truck
    496truck 1/2 ton status
    Jul 22, 2009
    4,478
    Carver MA
    Your truck no longer has to pass a "sniffer test" BUT the inspector is still required to do a visual inspection for safety and emissions. The inspector should be looking under the hood and under the car/truck for the original emissions equipment is not only there but hooked up. Unless you are taking it to one of those stations that check the lights, horn, tires and done, no cat=fail. Besides, as stated above, an aftermarket cat will flow significantly higher than the stock pancake and at that rate will not reduce your engines output and may actually increase it's torque vs. having no cat.
  9. GaBnn3
    Jan 2, 2005
    90
    Holyoke, Ma.
    Thanks all for your responses. I ordered the high-flow cat and cat back exhaust from J.C. Whitney. Now to get it on the road before the snow flies.
  10. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    3,959
    316
    NEBRASKA
    Mine came factory without one.
