Removing center pin?
Discussion in 'The Garage' started by sled_dog, Sep 20, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    How you go about this? I am trying to work on the 1 front Skyjacker I got from Swanson52(other got lost by Fedex). I loosened up the nut it only has a few threads left but the pin just spins now.
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Clap down the spring packs and put a pair of vise grips on the smooth side of the pin. Lay them flat on the ground and start wrenching. Works all the time, and if it starts to spin just tighten up the vise grips. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    I hope fed ex finds your other springs soon.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if that doesnt work, grind or torch one end off (being carefull not to hit the spring!) and you're done. If the nut is crusted on there, you're gonna need a new center pin anyway.
    j
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Angle grinder and cutting wheel. Will take it off no problem. Center pins are cheap, and you might as well replace it while your in there.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm not worried about the saving the spring, and I doubt fedex will find it since I've had this one for about 5 months now. Swanson is still working on getting my money back to me last time I checked. But I am glad I didn't throw the one spring out cause I figured out what to do with it /forums/images/graemlins/grin.gif I'm trying to get it down to just the last 2 springs so I can cut those down and use them in my planned 3/4 eliptical rear setup. I can't wait to get this project underway. 57" fords with 3/4 eliptical, should flex real nice.
