Removing(cutting?) messed up wheel stud..
Discussion in 'The Garage' started by TylerT, Jul 17, 2006.
  1. TylerT
    TylerT Registered Member
    May 30, 2005
    40
    OKC
    I've got a wheel stud that's become unseated. I was able to get off all lug nuts except for one, it was being a real PIA. It was taking everything I had with a breaker bar and barely turning, then the whole stud started turning. I've tried every tool I own to hold the stud while turning the lug nut, but now it's cuttin' time. Anybody ever do this and if so, what did you use? I'm sure others who haven't had to do this would know a good way to do it as well.. Can anybody offer me some advice here? Thanks alot.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    If in the rear on a SF axle, just remove the shaft, drum, and wheel all attached then grind the stud away from the rear.
    Rear FF axle is treated just as a front axle.....described below.....
    If the front, then remove the wheel bearings and the rotor and wheel will come off attached. Grind the stud away in the same manner as the rear.
  3. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    yah what he said!
    I fogot we can pull these things apart from the outside. We used to get all kinds of different cars into the tire stores. Cheep grand Cherokees used to strip studs out all the time.
  4. TylerT
    May 30, 2005
    40
    OKC
    I knew I shoulda given more info...I didn't wanna post this in the sheet metal rigs forum, I love the quick replies in the garage. It's a 92 3/4ton Suburban, front, drivers' side. I was just gonna try the ol sawzall tomorrow, but maybe somebody has some insight..
  5. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Might try....
    I've had to snap off wheel studs that spun where the splines are,by using a long peice of pipe over a socket that fits snugly on the lug nut--,or an old 4 way lug wrench you dont care much about..but a 9/16" stud probably wont break!!..:doah:
    I've drilled a few out,but it took forever to drill it enough so I could chisel it off...a "nut cracker" tool might work,IF it will fit over the lug nut...:crazy:
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    You should be able to unbolt the unit bearing from the knuckle. (4 bolts i think)
    Make sure to take the nut holding the halfshaft in place too.
    ON edit, it make not be accessible until the rotor is off.. So you may have to cut the stud afterall.. You should replace that unit bearing while you're at it, and check the other side too.
    John
  7. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I just went through this with my friends Br*nco. It was on the pass rear, It hada 9", so we couldnt get to the shaft retaining bolts to get the shaft out to grind it from the rear.
    This method worked suprisingly well...
    - Get grinder with smallest dia wheel.
    - Grind stud and lug as far down to the wheel as possible
    - Center punch the stud
    - Use a drill with a large bit and drill that punch mark (this removes most of the tapered cone)
    - Rock wheel and it should break free.
    Took about 15 minutes...
