removing diff???
Discussion in 'The Garage' started by Bhintz, Mar 5, 2005.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Im in the middle of installing my lockrite in my D60 but I pushed the cross pin to far so now I think I need to remove the carrier b/c I cant get the cross pin back in from the pinion side, so if I pull the diff , can i just unscrew the cap and remove the diff and cross pin put the lockrite in then put the diff back in place or is there shims and stuff that need to be put in right b/c I really have know skill in that ?????
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I have a service manual for the power lock for the dana60 and they show a "case spreader" to remove the carrier/ring gear. How much was the lockrite and where did you get it?
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    if the pin is still in carries you just need to wiggle the lock rite and it should go in. and the dana axles are tight fit on carrier to case. most use a BIG pry bar and or case spreeder.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Wait, you cant just spin the carrier around and push the pin back in? You should be able to do that, you dont have to take the whole carrier out. If you want to, then get 2 big prybars both on the top and bottom of the ring gear bolts, or one on the bottom on the bolt side and the top of the gear side. Remember to put the caps back in the same spot.
