Removing disks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rick, Feb 6, 2003.
  1. Rick
    Rick Registered Member
    Oct 12, 2002
    16
    Bonifay, Fl.
    Can someone explain how to remove the discs, I have auto locking hubs on a 10 bolt, thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    remove calipers and remove hubs screws and remove clip and washer and hub auto body assembly theres a nut in there somewhere- its large
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    never dealt with auto hubs, so someone can tell you how to get those out...but once the hubs are out you will need a special hub socket tool (the kinda that has 4-prongs on it)Then stick it in there and take off the first lock nut, then you need to take out the lock washer with a pair of needle nose pliars or a small screw driver. Once the washer is out, use the hub socket to take of the inner hub nut, once the inner hub nut is off, the entire hub/rotor assembly will come off..to take to rotor off, you need to drivew out the wheel studs....I just use a 3lb sledge and replace the ones that are FUBAR. Install is reverse of removal, but be sure you set the torque specs CORRECTLY on the innner nut or you will smoke the bearing or have a wobly wheel...I do mine by feel so I don't know what the exact torque for the inner nut is, but I think it is around 35-45#...
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I would also like to know what the proper torque is for those wheel nuts, ive been doing mine by feel too but since I have a torque wrench i may as well use it
