Removing doors with power accessories?
Discussion in 'The Garage' started by Lance, Jun 13, 2003.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I've searched on here for removing the doors and found lots of useful information for those units without power accessories. Can't find any info on how to do it if you have power window or door locks. I know someone here has to have encountered this. Please point me in the right direction. /forums/images/graemlins/1zhelp.gif
    Thanks,
    Lance
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can try unplugging the harness where it connects to the main harness, down near the kick panels, but the only thing limiting you from pulling the harness out with the doors is that damned rubber grommet, you may be able to cut this out though, good luck and I hope that made sense! /forums/images/graemlins/thinking.gif
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    its no biggie, all the power stuff in doors have wiring that have easy-to-disconnect connectors. If you take your door panels off and look around inside the door you'll find the window/lock wiring, just unplug em and you're on ur way.
    j
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Just unplug the wire harness on both sides just above the kick panel. You may have to remove the kick panel to see them. Then drill out the rivots hoilding the rubber boot to the truck. Then carefuly pull them out. Yu may have to unbolt the door hinges to drill the rivots.
    Good luck
  5. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    you can do what was mentioned above or just cut the wires and add these connectors.
  6. dyeager535
    26,980
    No offense, but I'd never use those in a hinge situation.
    If I were going to do anything like cutting the wires, I'd go find those sweet setups from the new vehicles. No wires, just metal contacts kind of like the door jamb switches on our trucks.
  7. BOWTIE
    Dec 28, 2000
    2,018
    no offence taken.. /forums/images/graemlins/thumb.gif there's prolly alot of things on my rig that others wouldn't do, so i'm use to it. /forums/images/graemlins/rotfl.gif
  8. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks to everyone for their input. Most everyone hit on the problem I was having, you can disconnect them on the truck side or the door side, but you still have the issue with the grommets and the wires that run through it.
    dyeager, got any idea on where to pick up those contacts or a place to start my search? This sounds like the ticket to keep the door removal / replacement time to a minimum.
    Thanks again everyone!!! /forums/images/graemlins/thumb.gif
    Lance
  9. dyeager535
    26,980
    Minivans started getting them pretty early on the sliding side doors.
    Friend has an '86(pretty sure thats right) Astro that has them on the sliding door. For other setups (more or less contacts) I'd look at all newer (say late late 90's) vehicles though, I have a feeling most every maker has gone (or will) to that style.
    But vans are the obvious first step, since the side doors slide and that makes wiring difficult.
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    You can get the Wireless kit from LMC Truck and you may be able to get it from Summit but I'm not sure... /forums/images/graemlins/thinking.gif
  11. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks for the tip!
    Lance
