removing engine
Discussion in 'The Garage' started by adamforsythe, May 28, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I am removing the engine and tranny out of my '85 k5 today. Anyone have any tips for me?
    Adam
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    unbolt everything and pull it out, make sure you support the trans when you pull the motor
  3. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    its purdy easy..i yanked mine during my one hour lunch break at work, back when i did it..some tips i can give is..mine was lifted 4 inches on 35s..cherry picker wouldnt reach, let air out of front tires to tilt the front end down, cherry picker still wouldn't reach..so i grabbed a set of un mounted 'yota rims and threw them on the front, and just set them on the ground..the picker reached then...so before you start make sure your picker reaches the engine, and has enough lift left to clear the motor of the radiatior support...it really sucks having the engine hanging and not be able to go any higer to clear...other tips..hmm..disconnect the battery, pull radiator and shroud, disconect hoses, disconnect exhaust, disconnect drive shaft, disconnect any wires that remain in the truck, unbolt tranny from mount, hook up picker, unblot motor mounts and pull it all out as one piece (engine and tranny) i left everything else hooked up to the engine (fan clutch, alt, ps pump, ac pump..just pulled it all as one big piece..like i said i had mine ripped out in a hour..of course i have done it several times..depending on your skill, you might want to drop the tranny first, then pull the motor..i'll probably be around most of the day, run into anything drop me a pm, and i'll answer any questions you might have
  4. BIG*RED
    Mar 14, 2003
    1,094
    make sure you support the trans when you pull the motor[/QUOTE]
    i think he is pulling the trans too, so he can eaither drop the trans first, or pull them out together...
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I pulled all of my radiatiors, the front of my engine (water pump, air, pS pump, alt.) So there is about 2 feet of room from the front of the block to the radiatior support. I yanked my t-case last weekend. The only thing I have left to do it to pull the tranny dip stick tube, and then hook the hoist up and pull the motor mounts. I think it should go pretty easy.
    Adam
  6. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    Pulling it out is easy.........getting it back in is the hard part. :cool1:
  7. BIG*RED
    Mar 14, 2003
    1,094
    yeah it can be, lol..my buddy and i ended up having to "man handle" mine..dang motor mounts would not line up, while hooked to the cherry picker, so we un hooked it, and each grabbed a side, and with alot of grunting, lifted and placed the engine where it needed to be..
  8. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    engine work is always more fun then anything like, suspension or something like that
    i guess b/c u spend alot less time under the car
