Removing flexplate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Mar 26, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    OK, another one of my noobish questions. What do you guys use to hold the engine from turning while removing the flexplate?
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    there's a special tool you can get that hooks on to your flexplate to hold it while you loosen or tighten the bolts. i don't remember what it's called exactly.
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I use an impact wrench to remove the bolts.
    John
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i stuck a BIG flat screw drive into the starter and wedged it, but an impact would be your best bet.
  5. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    I'm pretty sure that the tool that you're refering to is called a Spanner Wrench.
    I don't have one of those, nor do I have an impact gun, instead I usually just put a 1/2 drive extension through one of the holes that's in the flexplate and wedge it against the oilpan to help me crack loose the bolts.
    I do the same when reenstalling them too.
    The same trick works for me when I'm tightening the 3 Torque Converter bolts (which attach to the flexplate /forums/images/graemlins/wink.gif
    Hope this gives you some ideas.
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    that's what that thing is called. i've also done it the way your talking about and also the screwdriver trick. the times i have messed with flexplate removal and installation i've mostly just wedged it with a screwdriver.
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can bend the flesplate by doing that method(sticking a srew driver in one of the holes. Best bet is to go buy the correct tool. You will use it more that once.
    Dan
  8. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    [/ QUOTE ] yes ive done both and the impact is the way to go. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Okay, using an impact gun connected to the crank is not recommended. There is a risk of deforming your soft bearings from the reciprocating vibrations of the impact gun. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  10. muddysub
    Jun 23, 2001
    10,451
    489
    really? thats good to know, NOW!
    oh well its still runnin.
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Sample, check with AutoZone or Checker, see if you can rent that tool.
