removing front clip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, May 30, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    bout to do this, anyone got any advice as to how? i heard there were like 8 bolts? i have a 76 K5 btw.
    phill
  2. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ttt, come one someone help me on this i really have no idea cause i have never done this.
    phill
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Just helped a friend do it on his 86..Had to remove the doors to get to the one bolt on the inside..Also had to remove the bumper.. But other then that there where only about 8 bolts..Dan
  4. shupach
    Dec 28, 2000
    648
    Dallas, TX
    sweet, where exactly are the bolts? and why is ur username thing green?
    phill
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK on each fender there is 1 at the top back corner in the hood. (on 81 up this would be under the cowl cover) 1 in the door at the top. 1 under the fender from the rocker out behind the wheel. Remove the wheel house and theres 1 in there to the cowl (firewall) Body mount bolt at radiator support. And the wiring harness. I think that about covers it.
    These are the ones to remove the clip in 1 piece.
    If you look at the pics I have in "PI under construction" on Webshots you may be able to see most of the bolt holes. I have an 86 but its the same on the earlier ones.
  6. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    And if your pulling the clip in one piece you will need to remove the front tires as the inerfenderwells will bind on the tire.....
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    whatchya up to there, phillip?
  8. shupach
    Dec 28, 2000
    648
    Dallas, TX
    aight thanks for the info
    bryan - wouldnt u like to know...heheh, jk, takin the engine and tranny out, rebuilding the 400 w/ little goodies such as the edelbrock multi port fuel injection (bday present), gonna up the cr to 9.5:1 and dunno the rest of the details, my physic teacher's husband used to drag race professionally and he's gonna help out w/ the build up.
    cya at the meeting next thursday
    phill
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    The inner fenders MUST come off to access the bolt under them. (I think) Its been a while since I had mine off so I may be wrong now that I think about my previous post.
    And the tires will only interfere if your tires ar in the fenders. /forums/images/icons/wink.gif
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    You dont need to take the fenderwells or tires off. Make sure you disconnect what little wiring is attached to the fenderwells and fenders. Done forget the heater hoses, you might want to take those off. Get a couple of buddies to help out in the removal, I did it with one other friend and what a pain in the a$$ that was. If I remember right I swore I wasnt going to do it that way again for some reason. Have fun.
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    The innerfenderwells don't need to come off. And the front tires can stay on. It comes off in one piece.. I'm green cause I am moderator for Nor-Cal Big Dawgs forum....Dan
  12. Stomper
    May 11, 2002
    3,767
    Iowa
    You're right the tires don't have to come off but if you are trying to make it EZ It sure don't hurt anything...:)
  13. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Yep I was wrong. I went and looked at my pics and didnt see what I was thinking about. Hey cut me some slack I have been working on cars for a living for over 13 yrs. Theyre starting to all blend together I guess. LOL!
