Removing front Pinion bearing
Discussion in 'The Garage' started by Masher, Jan 27, 2004.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    Does anyone have any tricks for removing the front pinion bearing on a dana 60?? I don't really want to buy a special puller if I don't have to. There is really no room to get behind it either to try and drive it off with a punch, it sits right against the pinion teeth.
  2. Masher
    Mar 7, 2002
    123
    SW Michigan
    Anyone? /forums/images/graemlins/1zhelp.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Your supposed to put a puller behind the bearing and press the pinion off. The only other way aould be to cut the cage off, then cut the piece around the pinion with a little die grinder, but waaaay to much work. Just go to a shop that does gears, they should be able to do it for you.
