removing front spring/shackle bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Sep 4, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I am going to install ORD greasable shackles. It looks easy enough, the only tricky part might getting the bushings out. I have the factory bushing in the upper shackle, and the skyjacker poly ones at both ends of the spring. I think the upper shackle bushing will fall out, but I think the spring bushings may not want to come out. They have only been there about a month, and rust is not a problem here,so will they be hard to get out? Whats an easy way to get them out? A torch isn't an option for me cause...uh...I'm accident prone. Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    both bushing sets should be easy to get out.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    If you can't get them out try drilling holes around the bushing, this eases the tension on the bushing and you can knock them right out. I am getting ready to change the top front bushing on my blazer. I figure if I wait two more weeks they won't even be there anymore!!!
    creepin' and crawlin'
    Jim
  4. BI U JIMMY
    BI U JIMMY Registered Member
    May 20, 2000
    74
    I just installed the ORD greasable shackles and it was pretty straightforward. I drilled small holes around the metal in the bushing and they came out without much trouble.
