Removing leaf springs for more flex
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GUMBY, Oct 8, 2002.
  1. GUMBY
    GUMBY Registered Member
    May 17, 2000
    35
    Alabama
    I have a chevy 1-ton 4x4 crew cab that I removed the bed from and shortened the frame. I installed a skyjacker 8" lift. The rear spring packs were made to be used on a 1-ton truck that was used as a truck. I no longer have anything back there to create weight but a spare tire and gas tank. I want to remove some of the leafs to create more flex. Has anyone done this before? How many leafs and which ones should I start with? What do I need to consider when doing this?
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    My springs have two out of the front pack and one out of the rear. It will help with flex, but will also shorten their life span. If you take them out, take the shortest ones out first. If you dont tow anything then pitch the overload and it wil do wonders.
  3. GUMBY
    May 17, 2000
    35
    Alabama
    thanks
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Another option is to simply flip the overload leaf so it arches down.Yeah I removed one of my leafs in the rear too....great flex,but no load carrying abilities!!
