Removing leafs from the pack??
Discussion in 'The Garage' started by K5thatShmobs, Feb 21, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im running 8" Skyjacker leafs all around and Im wondering about removing leafs from the spring packs for some more flex. What leafs are best to remove? Will I lose lift? Who has done this?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Just as an FYI, I have 9" of lift in back consisting of 4" BDS springs, ORD 4" shackle flip, and a 1" relocating block.
    I flipped the overload spring and lost about 1.5" of ride heigth. However, with the overload flipped, it rode better than ever. Another con would be the rest of the spring pack would probably deteriorate much faster without the overload.
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i've done this to my 8s and it did drop my ride about 1-1 1/2. don't know exactly what i lost because i didn't measure before i did it.
    the bottom leaf is what i took out along with the degree shim. better ride and alot softer on the trail.
    just took awile to get use to the way it handles, kinda like when you take off the sway bar and drive it the first time.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If you're after ride quality or flex, overloads first then start with the shortest leaf.
    I flipped the overload on my 3/4t Sub upside down ('cup' facing down). Made a huge improvement in rear ride quality w/o completely loosing overload capacity. Don't know if this will work on a K5 or not.
