removing master cylinder
Discussion in 'The Garage' started by BranndonC, Sep 10, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    how do i get it out, i've unbolted it from the firewall, but the shaft inthe rear going through the firewall is a PITA to get out and i cant un screw it from the inside, any pointers?
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Real dumb ???? but did you take the cotter pin out of the pedal where the rod attaches to the pin.. /forums/images/graemlins/dunno.gif
    I am sure you did but have to ask /forums/images/graemlins/whistling.gif
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    it is a PITA to get to the pedal assembly to get the cotter pin out. Other than the six bolts on the firewall and the lever going to the brake pedal that is it. I have done this quite a few times in my truck /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif the what out of the who ? no i didnt, i didnt know what to do, its kinda like when i tried to pull my motor/tranny/t-case and didnt unbolt the floor shifter /forums/images/graemlins/doah.gif i'll look for that cotter pin. thanks /forums/images/graemlins/peace.gif
  5. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
  6. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    Under the dash on the pedal assembly. you'll see the rod with the cotter key. There is a bolt that runs thru a bracket, it's either 15mm or 9/16 dependeding on the year. Take the bracket off to access the cotter key.
  7. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    and, umm, the cotter pin under the dash is to remoev the BOOSTER ... the master just unbolts from the booster.
    Yes, you prolly should replace both at once ... but you did say master cylinder... /forums/images/graemlins/laugh.gif
    -- A
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i knew that /forums/images/graemlins/whistling.gif just got the two mixed up, thats all, now will a 1/2 ton master cylinder work with a 1 ton booster?
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    As long as themounting bolts on the Booster line up with the MC your golden /forums/images/graemlins/thumb.gif
    Make sure the rod inbetween the MC and booster is long enough.
    When I put in my 3/4 ton Booster it bolted right up.I did adjust the rod slightly.Some have a threaded end so you can fine tune them.
