Removing moulding, and have ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerWheels, Jan 5, 2004.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Removing moulding, and have ?\'s
    I am in the middle of removing the "chrome" moulding from my /forums/images/graemlins/k5.gif. I have 2 questions...
    1. What works best at removing the adhesive foam tape without screwing up paint? (using Goof-Off, but it takes forever and a lot of rubbing)
    2. Are there holes under the back corner pieces? If so, how many? and How big?
    Thanks in advance. /forums/images/graemlins/thumb.gif
  2. dyeager535
    26,982
    191
    Re: Removing moulding, and have ?\'s
    Two holes under each rear corner piece. I'd guess they are 1/4"
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    No idea, there is on my dads 81
    Goto a auto paint store and buy what is called an Eraser Wheel...mounts on a hand drill motor and erases the adhesive and DOES NOT HARM the paint...guy at the local body shop here in my town told me about this /forums/images/graemlins/thumb.gif
  4. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    ditto on the rubber wheel, citrus cleaner works good to get the glue off also.
    when my dad and i were doing the bodywork on my k5, i do remember there being 2 holes equally spaced under the taillight going around the corner.
    i had welded them up and didnt put molding back on.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When I took my trim off for paint a couple of years ago, I used a shop towel and liberal applications of 99% isopropyl alcohol. The adhesive came off really easily and with minimal elbow grease.
  6. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    theres stuff we use at the dealership called
    "3m adhesive remover ". it works great . you find
    find it at some paint and auto stores /forums/images/graemlins/thumb.gif
  7. BlazerWheels
    Feb 13, 2003
    587
    California
    Does the 3M stuff or the Alcohol hurt the paint??
  8. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    no it shouldnt, but who knows if your paint is the original or a repaint.
    always best to test in an inconspicous area first.
  9. k5fd89
    k5fd89 Hold my beer..watch this! Premium Member
    Sep 28, 2003
    237
    Baton Rouge, Louisiana
    Go buy a cheap heat gun...I have take the molding of three trucks with a $25 dollar black and decker heat gun with no damage to paint. Just go slow and don't heat any area to much. I usually work a couple spots at once. When the chrome trim get warm it pulls of and the tape comes too if not the tape will just roll off with your fingers or a little bug and tar remover.
  10. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    no , wqe use the 3m adhesive remover on new cars when we
    take the glue lines off from the factory. we also use it when we take off old pin stripe.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good stuff to know /forums/images/graemlins/thumb.gif
