Removing moulding
Discussion in 'The Garage' started by Tybee, Aug 24, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Whats the easiest way to remove the double sided tape left behind when removing the moulding. Ive tried adhesive remover with no luck.
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    One of the body guys at work has a wheel thats like a big eraser, kinda like rubber, that takes the sticky tape right off and doesn't mar the paint.
    Jim
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ive heard you can heat it up and peel it off.
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Wow quick responses, ill try that, thanks guys.
  5. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    If you heat it up and remove as much as possible it will leave some sticky residue behind. You can use adhesive remover to remove this, it will take some elbow grease and make sure that your rag has got a good bit of the remover on it.
